I didn’t know what exact happened with my router but now every device in my network is getting ipv6 DNS address first after router’s one:
DNS Servers . . . . . . . . . . . : fd1a:15fe:496f::1
10.5.7.1
Waht was done so far:
- disabled IPv6
- delted WAN6 interface
- odhcpd deamon stopped and disabled
- all IPv6 settings are disabled at all interfaces
My Configs:
network
root@GL-AXT1800:~# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
config device
option name 'br-lan'
option type 'bridge'
list ports 'eth1'
list ports 'eth2'
option multicast_to_unicast '0'
config device
option name 'eth1'
option macaddr 'xx:xx:xx:xx:xx:xx'
config device
option name 'eth2'
config interface 'lan'
option device 'br-lan'
option isolate '0'
option ipaddr '10.5.7.1'
option delegate '0'
option ipv6 '0'
config device
option name 'eth0'
config interface 'wan'
option device 'eth0'
option proto 'dhcp'
option ipv6 '0'
config interface 'wan6'
option proto 'dhcpv6'
option disabled '1'
config switch
option name 'switch0'
option reset '0'
option enable_vlan '0'
config interface 'guest'
option force_link '1'
option ipaddr '192.168.9.1'
option ip6assign '60'
option multicast_querier '0'
option igmp_snooping '0'
option isolate '0'
option bridge_empty '1'
config interface 'wwan'
option proto 'dhcp'
config rule 'policy_bypass_vpn'
option mark '0x60000/0x60000'
option lookup '53'
option priority '53'
config rule 'policy_via_vpn'
option mark '0x80000/0x80000'
option lookup '52'
option priority '52'
config rule 'policy_dns'
option mark '0x100000/0x100000'
option lookup '51'
option priority '51'
config interface 'wg2'
option proto 'wireguard'
option private_key 'xxxxx='
option peerdns '0'
list addresses '5.7.3.3/32'
option mtu '1380'
config wireguard_wg2
option description 'hm'
option endpoint_host 'test.example.com'
option route_allowed_ips '1'
list allowed_ips '5.7.1.0/24'
list allowed_ips '5.7.3.0/24'
option public_key 'yyyyy='
option endpoint_port '5382'
option persistent_keepalive '60'
config interface 'wgclient'
option proto 'wgclient'
option config 'peer_5238'
option disabled '1'
config device
option name 'wg2'
option multicast '1'
dhcp
root@GL-AXT1800:~# cat /etc/config/dhcp
config dnsmasq
option domainneeded '1'
option localise_queries '1'
option expandhosts '1'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option localservice '1'
option ednspacket_max '1232'
option rebind_protection '0'
option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
option strictorder '1'
option allservers '1'
list server '/home.loc/5.7.1.1'
option domain 'moro.loc'
option local '/lan/'
config dhcp 'lan'
option interface 'lan'
option leasetime '12h'
option dhcpv4 'server'
option start '2'
option limit '248'
list ra_flags 'none'
option dhcpv6 'disabled'
option ra 'disabled'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
option loglevel '4'
config dhcp 'guest'
option interface 'guest'
option start '100'
option limit '150'
config domain
option ip '10.5.7.1'
option name 'gl-inet'
but problem still persists, every new device mobile phone or PC are getting IPV6 address as well as IPv6 DNS with first priority anyway, how to get rid off it?
