Has anyone got this working? Under Wireless settings I’ve checked the Disable SSID box, saved, applied, rebooted but it still broadcasts the SSID and the box still shows SSID is disabled.
Thanks
Thanks
Hi.
Try doing it in Luci (Advanced settings, top right > Wifi > edit and uncheck the option there.
Regards,
Glitch
