Disappointed in Comet 5G, Not Failing Over to WWAN
The Fiber has been down where my Comet 5G is deployed for about 30 mins now and I can't reach it, it hasn't failed over to the WWAN (which I know is working, I was just SSHed into it yesterday and seeing increasing counts on the WWAN interface).
It's just showing greyed out on the GLKVM Web Interface.
It's not a power issue, it's plugged into a UPS ( and then a USB-C battery with passthru as additional backup) and the USB-C battery alone could power the Comet 5G for at least 8 hours).
.... you had ONE JOB, Comet 5G :confused:
So the Fiber came back up and I wanted to see if I could see if anything was wrong, and I couldn't find any issue- the Comet was up the entire time, and so was the wwan0 interface. On the Web interface, the WWAN was showing "Up" and even had good signal strength ... I'm at a loss as to what could have prevented failover.
Hi, thanks for reporting this issue. Could you please export the syslog and send it to us via PM?
Do they persist after a reboot? I was looking for logfiles before I'd rebooted :frowning:
The logs may be cleared after a reboot. If the issue happens again, you could collect the logs before rebooting the device.
Yeah, I'd figured ... thanks for the heads-up and I'll be sure to remember should this happen again.
