Discounts on Amazon don't work
There is a promotion to get an additional 10% off a various routers, but even after redeeming it, the discount doesn't get applied at the check out. I even tried using the "with brand promotion ZM27U7D71E3M" code manually.
I get an error:
The promotional code you entered cannot be applied to your purchase.
Anyone else is having this issue??
@Denisimo Are you trying to use the code in addition to a coupon?
Terms:
Unless the promotion indicates otherwise, it applies to the lowest priced qualifying item and may not be combined with other offers.
Coupons may not combine with other offers. All applicable offers will be evaluated and the highest discounts available will be applied in checkout.
