I have the log from the “log storage” section, about nas:
2023-03-01 06:37:59.556851
*** Request ***
uri: https://192.168.8.1:6000/GL_NAS_USER_LOGIN
data:
{name: root, pwd: *********************}
2023-03-01 06:37:59.605187
*** Response ***
Request Data: {name: root, pwd: *******************}
Response Text:
{“result_code”:5}
2023-03-01 06:37:59.733815
*** Request ***
data:
{name: root, pwd: ************************}
2023-03-01 06:37:59.751818
*** DioError ***:
DioError [DioErrorType.other]: SocketException: Connection refused (OS Error: Connection refused, errno = 61), address = 192.168.8.1, port = 58886
and also the log you asked from the log-windows:
2023-03-01 06:37:26.857418
*** Response ***
uri: http://192.168.8.1/rpc
Request Data: {“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“repeater”,“get_status”,{}],“id”:1}
Response Text:
{“id”:1,“jsonrpc”:“2.0”,“result”:{“state_name”:“idle”,“eap”:false,“state”:0}}
2023-03-01 06:37:26.868549
*** Response ***
Request Data: {“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“tethering”,“get_status”,{}],“id”:1}
Response Text:
{“id”:1,“jsonrpc”:“2.0”,“result”:{“err_msg”:“No device found. Please insert”,“err_code”:-2}}
2023-03-01 06:37:26.874136
*** Response ***
Request Data: {“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“cable”,“get_status”,{}],“id”:1}
Response Text:
{“id”:1,“jsonrpc”:“2.0”,“result”:{“status”:1,“mode”:0,“protocol”:“dhcp”,“ipv4”:{“gateway”:““,“dns”:[“89.101.160.4”,“89.101.160.5”],“ip”:”/23”}}}
2023-03-01 06:37:26.881889
*** Response ***
Request Data: {“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“modem”,“get_status”,{}],“id”:1}
Response Text:
{“id”:1,“jsonrpc”:“2.0”,“result”:{“modems”:[],“new_sms_count”:0}}
2023-03-01 06:37:29.383180
*** Request ***
data:
2023-03-01 06:37:29.430924
*** Response ***
Request Data: {name: root, pwd: **********************}
Response Text:
{“result_code”:5}
2023-03-01 06:37:29.432943
*** Request ***
data:
{“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“nas-web”,“set_nas_ser”,{“enable”:1}],“id”:1}
2023-03-01 06:37:29.436453
*** Request ***
data:
{“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“nas-web”,“get_status”,{}],“id”:1}
2023-03-01 06:37:29.463282
*** Response ***
Request Data: {“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“nas-web”,“get_status”,{}],“id”:1}
Response Text:
{“id”:1,“jsonrpc”:“2.0”,“result”:{“enable”:1}}
2023-03-01 06:37:29.464996
*** Request ***
data:
{“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“nas-web”,“get_proto_config”],“id”:1}
2023-03-01 06:37:29.528587
*** Response ***
Request Data: {“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“nas-web”,“get_proto_config”],“id”:1}
Response Text:
{“id”:1,“jsonrpc”:“2.0”,“result”:{“res”:[{“enable”:1,“port”:0,“name”:“samba”,“wan_access”:1},{“port”:6008,“name”:“webdav”,“wan_access”:1,“ssl_enable”:0,“enable”:1},{“enable”:1,“port”:0,“name”:“dlna”,“media_dir”:“/disk1_part1”}]}}
2023-03-01 06:37:29.552022
*** Response ***
Request Data: {“jsonrpc”:“2.0”,“method”:“call”,“params”:[“aBfrWR4EgdRXTtzJaCF2MesWJOUOP4uY”,“nas-web”,“set_nas_ser”,{“enable”:1}],“id”:1}
Response Text:
{“id”:1,“jsonrpc”:“2.0”,“result”:[]}
2023-03-01 06:37:29.553454
*** Request ***
data:
both logs was created when I click on “network storage” on the first page of the application.
I deleted the password (that is correct 100%) I don’t think there are other sensible information, in case let me know or delete the lines that you think are sensible.
thanks
regards
Piero
