I’ve just ordered GL-X750v2, which i intend to use for my van/mobile setup. It will be my main router (LTE+local wifi). I have also added GL-AR300M16 which will be used for wifi bridge (per need).
I usually use Pi Hole on raspi Zeros on my home setups for DNS filtering, but i would prefer this time to use something on router itsefl. Has anyone managed to run AdGuard or any other DSN filtering package for openwrt on GL-X750v2?
simple-adblock fits and works fairly well on devices as small as the USB150. You won’t get the pretty stats like you would from pihole, but you can still block a bunch of trash.
You can use Extroot onto an SD card /overlay partition. I did this on my AR300M just for personal amusement, but AdGuardHome was quite slow. The GL-X750V2 has the same CPU and flash storage.
