Hi team, I am using VPN with Policy Mode, I realized in AdGuard Home, there is native DNS being query, and it is towards my ISP DNS server.
May I know why does it happened? I didn’t put ISP DNS in the fallback server as well.
Screenshot as below, the port 53 is the ISP DNS.
Below is some strange log:
Sat Sep 13 16:21:52 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:52.820483 ERROR response received addr=202.ISP.DNS.IP:53 proto=udp status="exchanging with 202.ISP.DNS.IP:53 over udp: read udp 10.136.216.3:48468->202.ISP.DNS.IP:53: i/o timeout"
Sat Sep 13 16:21:52 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:52.820556 ERROR response received addr=ISP.DNS.IP.ADDR:53 proto=udp status="exchanging with ISP.DNS.IP.ADDR:53 over udp: read udp 10.136.216.3:33337->ISP.DNS.IP.ADDR:53: i/o timeout"
Sat Sep 13 16:21:52 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:52.820469 ERROR response received addr=202.ISP.DNS.IP:53 proto=udp status="exchanging with 202.ISP.DNS.IP:53 over udp: read udp 10.136.216.3:47109->202.ISP.DNS.IP:53: i/o timeout"
Sat Sep 13 16:21:52 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:52.820469 ERROR response received addr=ISP.DNS.IP.ADDR:53 proto=udp status="exchanging with ISP.DNS.IP.ADDR:53 over udp: read udp 10.136.216.3:37098->ISP.DNS.IP.ADDR:53: i/o timeout"
Sat Sep 13 16:21:52 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:52.820469 ERROR response received addr=202.ISP.DNS.IP:53 proto=udp status="exchanging with 202.ISP.DNS.IP:53 over udp: read udp 10.136.216.3:40288->202.ISP.DNS.IP:53: i/o timeout"
Sat Sep 13 16:21:52 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:52.820555 ERROR response received addr=ISP.DNS.IP.ADDR:53 proto=udp status="exchanging with ISP.DNS.IP.ADDR:53 over udp: read udp 10.136.216.3:47348->ISP.DNS.IP.ADDR:53: i/o timeout"
Sat Sep 13 16:21:53 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:53.828365 ERROR response received addr=202.ISP.DNS.IP:53 proto=udp status="exchanging with 202.ISP.DNS.IP:53 over udp: read udp 10.136.216.3:58295->202.ISP.DNS.IP:53: i/o timeout"
Sat Sep 13 16:21:53 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:53.828365 ERROR response received addr=ISP.DNS.IP.ADDR:53 proto=udp status="exchanging with ISP.DNS.IP.ADDR:53 over udp: read udp 10.136.216.3:56619->ISP.DNS.IP.ADDR:53: i/o timeout"
Sat Sep 13 16:21:53 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:53.828365 ERROR response received addr=202.ISP.DNS.IP:53 proto=udp status="exchanging with 202.ISP.DNS.IP:53 over udp: read udp 10.136.216.3:54678->202.ISP.DNS.IP:53: i/o timeout"
Sat Sep 13 16:21:53 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:53.828365 ERROR response received addr=202.ISP.DNS.IP:53 proto=udp status="exchanging with 202.ISP.DNS.IP:53 over udp: read udp 10.136.216.3:57947->202.ISP.DNS.IP:53: i/o timeout"
Sat Sep 13 16:21:53 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:53.828440 ERROR response received addr=ISP.DNS.IP.ADDR:53 proto=udp status="exchanging with ISP.DNS.IP.ADDR:53 over udp: read udp 10.136.216.3:42585->ISP.DNS.IP.ADDR:53: i/o timeout"
Sat Sep 13 16:21:53 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:21:53.828448 ERROR response received addr=ISP.DNS.IP.ADDR:53 proto=udp status="exchanging with ISP.DNS.IP.ADDR:53 over udp: read udp 10.136.216.3:34342->ISP.DNS.IP.ADDR:53: i/o timeout"
Sat Sep 13 16:25:21 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:25:21.976725 ERROR response received addr=202.ISP.DNS.IP:53 proto=udp status="exchanging with 202.ISP.DNS.IP:53 over udp: read udp 10.136.216.3:52042->202.ISP.DNS.IP:53: i/o timeout"
Sat Sep 13 16:25:21 2025 user.notice AdGuardHome[16006]: 2025/09/13 16:25:21.976711 ERROR response received addr=ISP.DNS.IP.ADDR:53 proto=udp status="exchanging with ISP.DNS.IP.ADDR:53 over udp: read udp 10.136.216.3:60753->ISP.DNS.IP.ADDR:53: i/o timeout"
