I noticed DNS leaks when connected to VPN using my Slate AX1800.
It always uses the DNS of the router I am connected via wifi instead of using the VPN DNS Server.
Setup:
Slate AX1800 in router mode connected over wifi to my main router.
I found the issue! Most probably a bug but it’s really strange.
If I configure VPN using the iOS App (gli.net) and use the predefined service providers than I have DNS Leaks. Used Mullvad with Wireguard.
If I configure VPN manually over the web interface of Slate AX than everything is fine.
I double checked with 2 VPN providers and exactly the same location and server (Mullvad and OVPN).
I’m using the latest beta of the Slate (4.0.1 beta2) and latest iOS version
It’s also strange that in the gli.net iOS app I can’t see the profiles which I added/configured using the webinterface of the router.
not really. I am still unable to see in the iOS app the profiles created manually thorugh the webinterface
I am not sure why the dns leak could be caused by app. If after you configure using app, then turn on/off via the web interface, will it has leask?
yes, it has leaks. Only time when there is no leak is if I use the profile which I configure manually thorugh the webinterface. Tried with 3 VPN providers so far (Mullvad, OVPN and ProtonVPN).
