DNS over TLS only works for the primary network, not the guest wifi. Is there a way to enable it to also handle guest wifi DNS?
Guest network should be the same, I will check.
I’m using the Flint router. With “Custom DNS” set, it applies to both private and guest wifi. However when I set “DNS over TLS” with the NextDNS option it only applies to the private network. Guest Wifi is defaulting to my ISP’s DNS.
I tested the AR750S without recurrence of the problem and will continue to use the Flint test.
I am also having this issue, can anyone help? I need DNS-over-TLS for both networks ideally. Thanks
