DNS resolution Failure 1ormore ENDPOINT DOMAINS
I'm setting up GL-MT6000 wireguard server Global options I enabled cascading & DDNS Do I still need to open ports in the GL router or dos it do it automatically? I connect the Client from outside house on 5g phone.
  1. If the VPN client did not enable on Flint 2, there is no need to turn on cascade. DDNS enabled is ok.
  2. There is no need to configure port forwarding on Flint 2. However if there is a primary router, it is necessary to open port forwarding on the primary router.
Please refer to the following guide:
Thanks Bruce, but it was my stupid mistakes. When I generated a Client Profile, I forgot to Click DDNS :man_facepalming: Anyways, What is Client to Client? I setup Flient 2 Wireguard server for home & taking Brume 2 Wireguard Client overseas :airplane: :flight_arrival: Any Tips or tricks to make them connect faster speed? This Guy on YouTube :tv: helpful https://www.youtube.com/watch?v=hKqTycmp0Rk
Not possible mostly. It depends on both sides internet connection.
I only enabled Adguard Home but IF I Enable Adguard home handle clients request will it mess up my working server client I just fixed? :thinking:
If I enable Client VPN on flint 2 for home, will it disable the VPN server?
No.
You can even cascade them: How to use VPN Cascading on GL.iNet routers - GL.iNet Router Docs 4
