This is the Beryl GL-MT1300 router.
Firmware: v3.215
Where do I collect the logs (I checked the System Logs in LuCI, but there's nothing there about DNS assignment after a VPN connection is established, other than the VPN Server setting the DNS Remote DNS Servers).
if I examine /tmp/resolv.conf.vpn, the file gets set properly:
nameserver 10.0.0.3
nameserver 10.0.0.1
Is there any other logs I can check?
Thu Oct 27 09:17:52 2022 user.info : 1247: gl-vpn-client>> Start, vpnpath=/etc/openvpn/ovpn10, serverfile=__ssl_vpn_config.ovpn
Thu Oct 27 09:17:52 2022 user.debug : ------ss-redir is not running!------
Thu Oct 27 09:17:52 2022 user.info : 1324: gl-vpn-client>> glconfig.openvpn.ovpn=/etc/openvpn/ovpn10/__ssl_vpn_config.ovpn, glconfig.openvpn.clientid=ovpn10
Thu Oct 27 09:17:55 2022 kern.info kernel: [ 784.735248] mtk_soc_eth 1e100000.ethernet: 0x100 = 0x6060000c, 0x10c = 0x80818
Thu Oct 27 09:17:55 2022 kern.info kernel: [ 784.752083] mtk_soc_eth 1e100000.ethernet: PPE started
Thu Oct 27 09:17:56 2022 daemon.warn openvpn[5287]: DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5287]: OpenVPN 2.5.2 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5287]: library versions: OpenSSL 1.1.1n 15 Mar 2022
Thu Oct 27 09:17:56 2022 daemon.warn openvpn[5299]: WARNING: No server certificate verification method has been enabled. See 2x HOW TO for more info.
Thu Oct 27 09:17:56 2022 daemon.warn openvpn[5299]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5299]: TCP/UDP: Preserving recently used remote address: [AF_INET][RemoteVPNServer]:443
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5299]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5299]: UDP link local: (not bound)
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5299]: UDP link remote: [AF_INET][RemoteVPNServer]:443
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5299]: TLS: Initial packet from [AF_INET][RemoteVPNServer]:443, sid=824edb63 27e72a17
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5299]: VERIFY OK: depth=1, C=US, ST=NA, L=NA, O=DOMAIN, OU=OU, CN=CERT
Thu Oct 27 09:17:56 2022 daemon.notice openvpn[5299]: VERIFY OK: depth=0, C=US, ST=NA, L=NA, O=DOMAIN, OU=OU, CN=CERT
Thu Oct 27 09:17:57 2022 daemon.notice openvpn[5299]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
Thu Oct 27 09:17:57 2022 daemon.notice openvpn[5299]: [CERT] Peer Connection Initiated with [AF_INET][RemoteVPNServer]:443
Thu Oct 27 09:17:58 2022 daemon.notice openvpn[5299]: SENT CONTROL [CERT]: 'PUSH_REQUEST' (status=1)
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: SENT CONTROL [CERT]: 'PUSH_REQUEST' (status=1)
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: PUSH: Received control message: 'PUSH_REPLY,route-gateway 172.16.0.129,sndbuf 0,rcvbuf 0,ping 45,ping-restart 180,redirect-gateway def1,topology subnet,route remote_host 255.255.255.255 net_gateway,inactive 900 7680,dhcp-option DNS 10.0.0.3,dhcp-option DNS 10.0.0.1,dhcp-option DOMAIN DOMAIN.local,ifconfig 172.16.0.130 255.255.255.0,peer-id 0,cipher AES-256-GCM'
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: timers and/or timeouts modified
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: --ifconfig/up options modified
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: route options modified
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: route-related options modified
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: peer-id set
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: adjusting link_mtu to 1625
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: OPTIONS IMPORT: data channel crypto options modified
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: Data Channel: using negotiated cipher 'AES-256-GCM'
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: net_route_v4_best_gw query: dst 0.0.0.0
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: net_route_v4_best_gw result: via 10.0.1.253 dev apclix0
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: TUN/TAP device tun0 opened
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: net_iface_mtu_set: mtu 1500 for tun0
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: net_iface_up: set tun0 up
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: net_addr_v4_add: 172.16.0.130/24 dev tun0
Thu Oct 27 09:18:03 2022 daemon.notice openvpn[5299]: /etc/openvpn/update-resolv-conf tun0 1500 1553 172.16.0.130 255.255.255.0 init
Thu Oct 27 09:18:05 2022 daemon.notice openvpn[5299]: net_route_v4_add: [RemoteVPNServer]/32 via 10.0.1.253 dev [NULL] table 0 metric -1
Thu Oct 27 09:18:05 2022 daemon.notice openvpn[5299]: net_route_v4_add: 0.0.0.0/1 via 172.16.0.129 dev [NULL] table 0 metric -1
Thu Oct 27 09:18:05 2022 daemon.notice openvpn[5299]: net_route_v4_add: 128.0.0.0/1 via 172.16.0.129 dev [NULL] table 0 metric -1
Thu Oct 27 09:18:06 2022 user.info mwan3rtmon[2672]: Detect rtchange event.
Thu Oct 27 09:18:06 2022 user.notice firewall: Reloading firewall due to ifup of ovpn (tun0)
Thu Oct 27 09:18:08 2022 user.notice root: check route success
Thu Oct 27 09:18:08 2022 daemon.warn openvpn[5299]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Thu Oct 27 09:18:08 2022 daemon.notice openvpn[5299]: Initialization Sequence Completed
