Is there any way the dnscrypt-proxy package on the gl-inet repository could be updated?
It’s currently pushing v 1.4.3, whereas the author’s github makes v 1.9.4 available. v 1.4.3 seems to have issues binding its socket on some hardware (I’ve been trying to get it to work on the ‘azure’ all day) and consequently won’t operate as designed; this is reported to be resolved in subsequent package updates.
Many thanks,
alzhao
April 18, 2017, 9:55am
2
We will try to update to v1.9.4 but this will be in next firmware release.
Which router are you using? I think you can just download the newest ipk from lede or openwrt trunk and install it in the router.
bli
February 9, 2018, 3:09pm
3
Please add support for DNScrypt + DNSSEC from DNScrypt.nl !
Or make it work like Tomato firmware, with easy menu:
any update? still not available in the latest repo.
GL-AR300M
LEDE Reboot 17.01.4 r3560-79f57e422d / LuCI lede-17.01 branch (git-17.290.79498-d3f0685)
Can you provide a way to install this manually through ipk?
alzhao
June 25, 2018, 5:04am
5
Pls find dnscrypt 1.9.4 from Index of /releases/17.01.4/packages/mips_24kc/packages/ and try to install using opkg.
that’s the old version, what about 2?
can I install this one?
which release/cpu is the correct one?
[](https://opencollective.com/dnscrypt)
[](https://github.com/dnscrypt/dnscrypt-proxy/releases/latest)
[](https://github.com/DNSCrypt/dnscrypt-proxy/actions)
[](https://matrix.to/#/#dnscrypt-proxy:matrix.org)
## Overview
A flexible DNS proxy, with support for modern encrypted DNS protocols such as [DNSCrypt v2](https://dnscrypt.info/protocol), [DNS-over-HTTPS](https://www.rfc-editor.org/rfc/rfc8484.txt), [Anonymized DNSCrypt](https://github.com/DNSCrypt/dnscrypt-protocol/blob/master/ANONYMIZED-DNSCRYPT.txt) and [ODoH (Oblivious DoH)](https://github.com/DNSCrypt/dnscrypt-resolvers/blob/master/v3/odoh-servers.md).
* **[dnscrypt-proxy documentation](https://dnscrypt.info/doc) ← Start here**
* [DNSCrypt project home page](https://dnscrypt.info/)
* [Discussions](https://github.com/DNSCrypt/dnscrypt-proxy/discussions)
* [DNS-over-HTTPS and DNSCrypt resolvers](https://dnscrypt.info/public-servers)
* [Server and client implementations](https://dnscrypt.info/implementations)
* [DNS stamps](https://dnscrypt.info/stamps)
* [FAQ](https://dnscrypt.info/faq)
This file has been truncated. show original
@elRadix Doesn’t the v1.9.5 meet your need?
