Hi All, looking for some help configuring dnsmasq as 2 instances. Background, need a second set of devices on the network to have seperate dns servers and I want to use dnsmasq for it so I get logging and as well as can operate specific requests with server routings.
I can successfully setup the dns aspect, the 2nd instance I put on port 54 and thus for dns there's no conflict and I get the other clients redirected with a firewal rule.
The issue I have is that I cannot seem to stop DHCP for the 2nd instance, so I'm clearly doing something wrong, below is an example of my dhcp config file. If I set the dhcp option to 'disabled' on the 2nd instance it also stops dhcp on the first instance. If I leave it as 'server' it of course conflicts with the first instance and is trying to give out dhcp leases causing network chaos.
Would be grateful for any direction. I'm trying to keep things simple and this seemed to be the cleanest route to go.
config dnsmasq 'lan'
option domainneeded '1'
option localise_queries '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option authoritative '1'
option readethers '1'
option sequential_ip '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
option serversfile '/etc/noads.split.servers'
option localservice '1'
option ednspacket_max '1232'
option rebind_protection '1'
option logqueries '1'
option noresolv '1'
list server '1.0.0.3'
list server '1.1.1.3'
config dnsmasq 'smart_dns'
option domain 'lan'
option authoritative '0'
option strictorder '1'
option port '54'
option noresolv '1'
list server 'x.x.x.x'
config dhcp 'lan'
option interface 'lan'
option start '100'
option dhcpv4 'server'
option ra_slaac '1'
option force '1'
option dhcpv6 'disabled'
option ra 'disabled'
option ignore '0'
option limit '92'
option leasetime '720m'
config dhcp 'smart_dns'
option instance 'smart_dns'
option interface 'smart_dns'
option dhcpv4 'disabled'
option ra_slaac '1'
option force '1'
option ignore '0'
