Hello GL-iNet users,
I am wondering if it is possible to stop the subnet of the main router to which the GL-AX1800 is connected being routed.
The Setup:
Internet (DSL) <-> FRITZ!Box (Router) <-> GL-AX1800 (Router)
Public IP <-> 192.168.179.1 <-> 192.168.179.47
The FRITZ!Box (192.168.179.0/24) is providing internet access and also has a couple of clients directly connected. The GL-AX1800 (router mode, 192.168.95.0/24 and 192.168.96.0/24 for the guest network) is connected to the FRITZ!Box and should provide an isolated network for all clients connected to the GL-AX1800.
I would like to prevent any client behind the GL-AX1800 (on the regular and guest network) to be able to connect to any IP address provided by the FRITZ!Box.
In short all clients behind GL-AX1800 should not be able to access any 192.168.179.0/24 address.
Is there a way to configure this?
(I can’t put the GL-AX1800 into a “guest network” provided by the FRITZ!Box because I can’t configure port forwads on the FRITZ!Box to devices which are in the “guest network”)
Greetings,
Bjoern
