hi,
i am using A1300, want to setup a client in this router for service: vless, naive
Is that correct understanding that only have to setup a speicial version of Openwrt which support vless and naive is this solution?
It seems in advance setting- luci (as a kind of Openwrt) doesn’t support vless, naive or v2ray…?
Yes, we do not support all such services, including vless, vmess, v2ray, shadowsock …
You can’t see them in the LuCI of the standard firmware, nor can you download and install them through the GL software source.
