I think to get the new Comet X (GL-RM4PE) Quad-Port Remote KVM with PoE.
I would use it to replace two CometPRO devices.
One of the existing COMET Pro GLRM-10 devices which would be replaced is connected to a server which uses the ATX power board, and I installed the ATX power board a while back and I’ve been able to successfully use the COMET Pro to turn on and off the server with that ATX board.
If the new Comet X were to replace the COMET Pro on that server would the installed ATX board be compatible with the new COMET X? Would I simply be able to unplug from the Comet Pro the cable connecting the ATX board and plug that in to the USB of the corresponding USB connector for the COMET X and it would work? I’m very curious to know?
Also, would the new COMET X allow for the webcam and microphone passthrough as some of the newer firmwares have enabled for Comet Pro?
thank you!
-eddie
-eddie
