Does the Cirrus line have Mesh services built in?
If not can you post instructions for manual configuration?
Unfortunately it does not have a pair button.
You can ssh to it and use the following command to put it in paring mode.
ACTION=released BUTTON=wps SEEN=5 /sbin/hotplug-call button &
Then get a B1300, and put it in paring mode using the pair button.
Can GL-iNet program the AP1300 such that a quick click of the reset button puts the device into Pairing mode?
Check these files
/etc/rc.button/reset
/usr/bin/button_released
It contains the script to program the reset button.
Thanks Alzhao.
This worked for me using two AP1300s.
