I wanna read the data of the RS422 serial device which was connected with GL E750 by a USB2RS422 cable.
You should install kmod-usb-serial-ftdi
Yes you are right.
Yes
does E750 also support those programming languages such as : C/Python ? support SSH login ?
support Java ?
C and Python are OK. Ssh is ok.
No Java.
