I am looking to control any 1 GPIO in the “out” direction with unmodified firmware. Is this possible? Or is my only option to disable i2c or serial or something already present sharing those pins and rebuild a firmware? (GPIO 4, 5, 45, 46, 12, or 13)
I should give more information. I’ve tried accessing the GPIO via /sys/class/gpio using the appropriate export and out direction and value setting as described here https://openwrt.org/docs/techref/hardware/port.gpio but I cannot get any pins to go HIGH 3.3v. I just wanted to know for certain before I start modifying firmware that I cannot do this using the firmware provided by GL.iNet.
I think that’s fine, as long as I can tell the difference between HIGH and LOW. As it is right now, any output I assign doesn’t register on my multimeter.
Hi @alzhao , I looked through the posts there and they don’t really tell me whether or not it is possible to use standard GPIO in the “out” direction without recompiling from source. They seem to get GPIO working after modifying some source and recompiling, but since GPIO is advertised in the product description, I’m hoping there is a way to use it without recompiling and flashing a custom openwrt.
