Hey I have a few GLAR300M devices, and cannot get it to work with Virgin Media SuperHub or my Netgear Nighthawk router (both of which are running on Channel 13 to avoid being on a congested channel).
I’m running a slightly older firmware v2.24 but just wanted to check if Channel 13 is supported? (I’m also UK if region matters too).
Yeah! It supports channel 13 in UK. But you should change the country code at first, to do this pls negative to luci → Network → Wiereless → Edit → Advanced Setting, clicking on Apply & Save button after changing. Then go back to gl ui, you can select 13 channel.
Thank you so much! Same situation; I need channel 13. Your trick works. However, with my GL.iNet White (GL-AR150 with firmware 3.201-release), I was not able to select channel 13 in GL UI then. I changed it via LuCI as well.
@GL.iNET, this is quite a popular request, at least I found a lot of threads via the search and you created even a Wiki entry. Two questions:
Is it planned to make the channel selection more dynamic, for example, when I changed to Germany via LuCI that I get channels 1 to 13 in GL UI? LuCI is dynamic and gave just 1 to 11 at start. After changing the country, LuCI gave 1 to 13. Would be handy if GL UI adopts already. Or is this a recently introduced regression? You filed that already… please, do a +1 on that bug report for me.
Is it planned to allow the user to change the country via GL UI as well?
