norcimo
November 18, 2017, 8:18am
Greetings,
We are currently using the MT300N-V1. We have about 75 units working perfectly with OpenWrt 15.05, with LuCi 15.05 branch.
It is crucial we keep using LuCi. Can you please advise is the new MT300N-V2 works with OpenWrt, Luci? We need
place large order on amazon, but I need to know if it will continue to work? What version will I need? I will order one unit to test.
Thank you
F.Cepeda
rangerz
November 18, 2017, 9:31am
2
All the firmware here is still based on a version of OpenWrt 15.05, but I do not know which one.
Luci is included on both the Gl.inet v1 (v1 folder for the v2 device) and the “clean” versions. You should find a link in the upper right hand corner of the GL.inet gui which will open Luci. The version info will be at the bottom.
alzhao
November 20, 2017, 3:17pm
3
MT300N-V2 is using LEDE 1701 and it has Luci as well.
Your old firmware for MT300N-V1 doesn’t work on V2. You need a new firmware.
norcimo
November 20, 2017, 8:14pm
4
Thanks for the response.
At this time we do a factory reset on V1 of the MT-300n, then we load Luci.
So basically, leave the firmware alone, just load luci…is this correct?
Thanks
norcimo
November 20, 2017, 9:06pm
5
can you provide the address for the FTP server? Where I can get the files? Thanks
glitch
November 20, 2017, 9:20pm
6
No, Luci is already inlcuded.
norcimo
November 20, 2017, 9:31pm
7
ok. Thanks… The unit is on its way. I will see it soon
Question, is the performance better than V1? By how much would you say? Wifi aspect.
alzhao
November 22, 2017, 10:17pm
9
It has double RAM and cpu is slightly faster. WiFi speed is improved as well.
