it doesn't work TOR , although everything was fine until this time, there were no changes in the device, it just stopped displaying the icon on the TOR display of the device, what should I do?
Device gl750 mudi
Is Tor setting/icon not displayed on the GL GUI? Or is it unable to connect after Tor is enabled?
Please tell me the firmware version.
My connection with TOR is not working and there is no icon either
my version is 4.3.19
Are there any restrictions in your local country for Tor?
Can other Tor clients connect normally? Such as the PC.
In addition, the connection process may be relatively long, please wait patiently.
Are there any restrictions in your country for Tor?
I don't know if there is anything like that, but it worked perfectly for me for a certain time, everything worked perfectly a month ago, it worked perfectly for 6 months
Can other Tor clients connect normally? For example, a PC.
Yes, they can
Also, the connection process can be relatively long, please wait patiently.
I understand this, I waited for 2 hours and nothing happened, the indicator keeps saying connecting and glowing yellow, this
Could this be because of the VPN connection before TOR?
We temporarily compiled a temporary firmware and incorporated a newer version of Tor. Please install it in your E750 and try to see if the Tor connection is normal.
Tips:
- Unofficial firmware may be reminded during installation, just ignore it.
- Do not check "keep settings" on installation
- This firmware is a temporary test firmware, which has not been fully tested, cannot be used for long-term use, and is only used for temporary verification.
How about the test firmware, does the Tor work well?
