Domain blocked but not able to unblock a client - AdGuardHome
Good morning,
I have blocked the domain ||gstatic.com^$important.(pls don't ask me why)
I have unblocked the domain for the client @@||connectivitycheck.gstatic.com^$client='hostname' (necessary for an android google smartphone)
Unfortunately, the domain remains blocked for the released host.
What is the reason for this and what must the correct syntax look like if the intended procedure does not work.
Thank you
Neuro
Does your AGH handles Clients directly? If no: This won't work.
Yes,
"AdGuard Home verwaltet Geräte Anfragen"
is activated.
This rule must be higher located then the deny rule, is it the case?
Du you mean the position in the blocklist or the logic?
Currently the unblock rule located some lines below the block rule...
Please learn the 'important' syntax:
It will be highest if the rule addes 'important', even the ignore the client in the below or above.
I add the hostname or device IP of my PC, remove the 'important', it works
Excellent, thank you Bruce for you support!!
Neuro
