gregg
March 1, 2016, 9:59am
Hi I flashed my domino core and the os is read only. It is missing the network, and wireless configs within /etc/config/ I cannot create them because it is read only. I have access via UART. How do I reflash it? Do I use uboot? I was reading the directions from the serial wiki on openwrt.org , but I am not sure which memory address to erase in the console.
Any help would be great!!
Thank you.
alzhao
March 2, 2016, 11:55am
2
When you flash new firmware, it will create a writable file system. If this is failed, you cannot write anything.
Generally the reasons include:
Too big firmware, no space to create the system
bugs in firmware.
Where does your firmware come from?
gregg
March 2, 2016, 12:03pm
3
I compiled it from the GLI git repo. I can get into uboot, I just cant figure out which address to start the erase from and what address to end with.
Below is what I see :
Device calibrated. Booting …
Booting image at: 0x9F050000
Image name: MIPS OpenWrt Linux-3.18.23
Created: 2016-02-28 23:28:27 UTC
Image type: MIPS Linux Kernel Image (lzma compressed)
Data size: 1141668 Bytes = 1.1 MB
Load address: 0x80060000
Entry point: 0x80060000
Uncompressing kernel image… OK!
Starting kernel…
I’m guessing I would issue the following to re-flash using kermit within the uboot interface:
erase 0x9F050000 +7c0000 (not sure how to get this number “+7c0000”)
loadb 0x80060000
<pre class=“code”>
alzhao
March 2, 2016, 12:08pm
4
why not just use the uboot WebUI?
Type "httpd" and it will start the UI,
Set your computer's IP to 192.168.1.2
then you can visit http://192.168.1.1/index.html using your browser
When you use erase, the number (+7c0000) is the size of your new firmware
gregg
March 2, 2016, 12:11pm
5
I do not have a NIC on the board, I only have UART access so I need to copy via Kermit. Is there a formula to find the Firmware size? Is it just a hexadecimal number of the file size, or is it a memory address?
gregg
March 2, 2016, 3:33pm
6
I soldered a cat 5 cable to the di board, but uboot states eth0 and/or eth1 is not up.
Orange White –> TX+
Orange —> TX-
Green White–> RX+
Green —> RX-
Any suggestions on how to fix it, or should I just pronounce it dead?
alzhao
March 2, 2016, 6:13pm
7
0x10000 = 64K
0xffffff = 16MB
0x800000 = 8MB
I am not sure it is dead. Seems you need to have some hardware skills to save it.
gregg
March 3, 2016, 10:46am
8
I soldered the Ethernet directly to the core, and it still does not work. I guess it goes in the trash pile.
Thanks for your assistance.
