Dont find “force VPN” on V3.005.1030 AR750 white on Admin menue.
I remember like this from V2.272 version.
To avoid data leak, v3.0 firmware has enabled Force VPN by default and removed this option from ui.
The “Force VPN” is a great feuture. That should be promoted by a short message on VPN menue. Becorse this function are why some people buy a vpn router.
On follow link on advanced admin menue (“Interfaces - OVPN”, menue item “Force link”
is for my not clear. Its sounds a little bit for me like “Force VPN” is disabled ???
http://192.168.8.1/cgi-bin/luci/admin/network/network/ovpn
They aren’t the same thing. Force link means specifies whether ip address, route, and optionally gateway are assigned to the interface regardless of the link being active (‘1’) or only after the link has become active (‘0’); when set to ‘1’, carrier sense events do not invoke hotplug handlers.
Ok. THX for you information. Thats one more my misunderstanding, releated on my verry small dictionary.
Again: That means:
