Drop in Speed on Spitx X3000 after snapshot 4.0 1100snapshot firmware update
After upgrading to version 4.0 1100snapshot I see a sudden drop in speed. I usually get no less than 500Mbps (download) and 80Mbps (upload). I had to update as I was getting frequent loss of connection after the previous beta version. I had to restart the router every time, thought the last snapshot build may resolve it (without reading fixes) but got into another trouble.
Yet another old issue that is appearing again on these firmware. It was fixed but I am facing it again.
Hi @realjohny
Regarding the issue where the network does not automatically reconnect, when the issue occurs,could you please help us collect the cellular debug log so that we can investigate further? The steps are as follows:
For the slow speed, please check the current band being used. You may try band masking to block out the current band and then let the router connect to another band to see whether the speed changes.
Also, we suggest downgrading to the previous firmware version to check whether the issue is related to the snapshot firmware. Thanks!
Do you have any data from the towers you were connecting to on the other versions?
