Dropbear support for ecdsa-sha2-nistp256 keys
On my GL-X3000 (OpenWrt 21.02-SNAPSHOT, r15812+882-46b6ee7ffc), I cannot authenticate over SSH using an ECDSA key, ecdsa-sha2-nistp256. This is the key type that can be stored securely within the Secure Enclave on Macs, which allows biometric authentication to the router.
Could Dropbear be compiled with DROPBEAR_ECC to support this algorithm?
I will try to evaluate this request for the Dropbear.
Thanks.
Try testing this temporary firmware for X3000, the dropbear compiles integrated ecdsa.
Hi, thanks for creating this. The transfer has already expired, could you please re-upload it?
Please check the attach
Thank you, I downloaded it. Before I install it -- I notice that the file is almost 10 MB smaller than the released firmware file openwrt-x3000-4.7.1-0106-1736138495.bin. Is that expected?
yes, this test firmware is only used to test dropbear's ecdsa.
X3000/XE3000 v4.7.x is supported ecdsa-sha2-nistp256.
I can confirm that it works, thank you.
