DS-Lite support for GL-BE9300 in Version 4.8.1
I read that with Version 4.8.1 for GL-BE9300 there is support for DS-Lite so that I can connect to Deutsche Giganetz as the use DS-Lite and an AFTR-Adress.
After installation there is still no Option to activate DS-Lite and a field for the AFTR–Adress.
Is this right or do I need to install an additional feature.
Thanks for your support.
DS-Lite is not currently supported by GL UI.
You may need to:
  1. First provide internet access to the BE9300 using your phone's hotspot
    Repeater - GL.iNet Router Docs 4
  2. SSH into the router and run the following commands to install DS-Lite support
opkg update
opkg install ds-lite
  1. Reboot the router
  2. Access Luci - Network - Interfaces, click the Edit button next to WAN
  3. Select Dual-Stack Lite for Protocol and click the Switch protocol button
  4. Configure the DS-Lite AFTR address and save
  5. Click the Save & Apply button to apply the configuration
