Dual Wan Load Balance + VPN Client On = No Internet Access
Has anyone found a solution for the above dilemma please?
It’s a known problem, and we’re trying to fix it.
Thanks for that. Do you happen to have a rough estimate on when an expected fix might happen?
We’re fixing it, but it’s complicated and will take some time.
Hello
is this fixed yet?
Is there a solution to this issue?
It is fixed in firmware 4.3.7 and later. Now there is a 4.5 firmware released. Pls try.
I have firmware 4.4.6 on my device and the upgrade page is saying that it’s up to date. I will search for 4.5 and give it a shot.
I updated to 4.5. It seems to be working for now. I will report back if it fails again.
Thanks!!
Just if someone comes around and is looking for the 4.5 firmware:
https://dl.gl-inet.com/
That’s where all downloads can be found.
