Dynamic DNS (DDNS).COM new GL-iNet Router
I just got Flint 2 router because I was told here my old Brume 2 it's to slow VPN. Anyways my question now as I setup the flint 2 is I already have a DDNS Enable GL-inet Dynamic DNS (DDNS).COM setup up or the brume 2 was a VPN server before on the netgear router I'm replacing with the Flint 2 home vpn router. Do
i just copy all the setup from the brume 2 and then add the flint to the cloud ? Should I remove old Gl-iNet devices on the cloud I don't use anymore?
You can't copy the backup, if this is the main question. However, you can copy all settings manually - yeah. Please keep in mind that the Flint 2 will have a new GLDDNS name, so you will need to change your VPN clients as well.
You are not required to do so, but yeah, I would do it.
