I got a problem with starting up my router. When I switch it on, “Booting …” progress bar is getting frozen roughly at 90%.
I tried following, but no success:
Holding reset for 4 seconds: no success
Holding reset for 10 seconds and trying power on, no success
Holding reset for 15 seconds with ethernet connected, I was not able to boot into uboot. Ethernet port never showed that there is a cable connected and status was the same (booting progress bar is stack at 90%)
Could you please advice, what can I do to move forward?
This is exactly what I was trying to do a lot of times. I have 2 questions.
Is it really important to use exactly cable from Mudi? I have a lot of usb-c cables (I tried with different ones, including Thunderbolt 4 certified cable). I’m not sure that i’ll be able to find Mudi cable, probably it will be easier to buy new one.
The results are always the same: i’m holding reset button with the stick and power on: and basically no difference, system just get stack on 90% of booting. (port replicator is connected to pc via Ethernet and to usb-c port on Mudi on other end).
I have multiple devices and with one of them I have this exact same issue. I can’t get into the uboot mode; If I hold reset button and turn it on it just starts the normal booting and stops at 90%; I’ve tried this with another device and it works; The first device is probably bricked… what is the solution for this problem? Device is 2 months old.
