When something happens on WAN interface, such as ISP changes IP at least once a day, the /dev/cdc-wdm0 modem doesn’t reconnect, unless e750 is rebooted.
Usually works ok for many hours; sometimes only a few minutes.
If interface restarted in Luci, last line in system log is:
Yes, when it happened, LTE connection breaks. I don’t know how to reconnect manually, except to push the interface Restart button or reboot the whole router.
The router kept the original IP, and even sometimes said it was connected to uqmi get-data-status, but wasn’t connected.
On the e750, the main WAN connection I have is the LTE. I don’t use ethernet port.
A few days now has been working without this problem. So, maybe was something temporary on the ISP network.
It worked with USB2 for these 4 weeks with minor problems.
Yesterday, it just stopped connecting to ISP and even in minicom.
Can still uplink to other devices through WIFI interface, but not LTE.
The LTE /dev/cdc-wdm0 and all ttyUSB devices disappeared and do not exist anymore in the file system.
I’m having trouble exchanging it through vendor who sold it, because of their bureaucracy. (Shopee)
Are there some other global LTE modules I can try that will work?
