E8372h modem usb disconnects
I have been using E8372h in tethering mode with GL-AXT1800 (fw 4.8.2) for a while at home and it's been great.
However, when I took my router on a trip I couldn't use the modem on the move as it's been constantly disconnecting as the cellular were often disconnecting and reconnecting to different towers.
I've been powering the router with 5V 3A as a power source and at home with modem it was consuming about 5.3W, so it still has around 10W to spare for any modem needs etc.
When the modem was briefly working it still was taking time to even connect to its admin UI at 192.168.8.1, which I suppose shouldn’t be the case even when cellular isn’t available to the modem.
I switched from USB3.0 to USB2.0 but it didn’t fix anything, same issue.
Logs:
i36.358504j usb 1•1: new high•speed USB device number 6 using
xhci•hcd
[ 236.7214391 cdc_ether 1-1:1.0 eth3: register •cdc_ether' at usb-
xhci-hcd.O.auto-1, CDC Ethernet Device Oc:5b:8f:27:9a:64
[ 236.7221841 qcom,cpr4-apss-regulator b018000,cpr4-ctrl: CPR
valid fuse count: 4
| 236.7324101 qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR
valid fuse count: 4
1 236.7393001 usb-storage 1-1:1.2: USB Mass Storage device
detected
1 236.7460901 scsi hostO: usb-storage 1-1:1.2
| 236.7537731 qcom,cpr4-apss-regulator b01 CPR
valid fuse count: 4
[ 237.8348271 scsi Direct-Access HUAWEI TF CARD
Storage 2.31 PQ: O ANSI: 2
1 237.8359351 sd Power-on or device reset occurred
[ 237.8437981 sd (sda) Attached SCSI removable disk
1 237.8476691 qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR
valid fuse count: 4
1 266.5479161 cdc_ether 1-1:1.0 eth3: unregister 'cdc_ether' usb-
1 267.0493301 usb 1-1: reset high-speed USB device number 6 using
xhci-hcd
[ 267.3552571 qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR
valid fuse count: 4
[ 267.4062761 cdc_ether 1-1:1.0 eth3: register •cdc_ether' at usb•
CDC Ethernet Device, Oc:5b:8f:27:9a:64
1 267.4067291 qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR
valid fuse count: 4
1 267.4449381 sd Power-on or device reset occurred
[ 280.2275331 cdc_ether 1-1:1.0 eth3: unregister •cdc_ether' usb•
[ 281.5270941 usb usbl •portl: Cannot enable. Maybe the USB cable
is bad?
[ 282.4869901 usb usbl-portl: Cannot enable. Maybe the USB cable
is bad?
[ 283.4469401 usb usbl -portl: Cannot enable- Maybe the USB cable
is bad?
[ 284.4069051 usb usbl-portl: Cannot enable. Maybe the USB cable
is bad?
1 284.4074421 usb 1-1: USB disconnect, device number 6
( 285.8269141 usb usbl-portl:
is bad?
[ 286.7868431 usb usbl-portl:
is bad?
1 286.7870051 usb usbl-portl
: attempt power cycle
1 287.8468341 usb usbl-portl
is bad?
1 288.8067931 usb usbl-portl:
is bad?
[ 288.8069501 usb usbl-portl:
unable to enumerate USB device
It seems to be caused by an unstable USB connection.
Is the E8372h currently connected directly to the AXT1800? Please try securing it with cable ties or using a USB extension cable.
As it’s a dongle style modem it’s directly connected to the router with built-in USB A. There weren’t any significant vibrations and even if I violently shake it at home it works perfectly, so I don’t think it’s an actual physical connection issue. I will try using an extender cable next time just to be sure.
