I am trying to get EasyTether (on Android Phone) to tether to the GL.Inet travel router model mt300n-v2
(link: https://docs.gl-inet.com/en/3/specification/gl-mt300n-v2/)
which uses the CPU MTK 7628NN 580MHz
WHICH IPK?
I think this is a Media Tek chipset, but the file might be under “ramips”.
Specifically, is the right file:
- ramips: mt76x8 / easytether-usb-tiny_0.8.9-5_mipsel_24kc.ipk
OR
- mediatek: mt7622 or mt 7623
Note and context: The docs do reference EasyTether
And that doc refers to
which says
"Find out the chip of your model (for example Atheros 9531, MediaTek MT7620N, etc) from the website. "
Unfortunately, there is ambiguity (to my newbee mind) about whether the right IPK for the chip here (MTK 7628NN) is in Mediatek folder or in the ramip folder.
Note2: This is the v2 version of the “mango” travel router. The v1 might be different.
Thanks!
