I need a 3:2 resolution EDID for my Surface Pro 8 @ 60 / 120.
I tried to import SP8’s EDID directly but it doesn’t work, it shows 2560x1440.
SP8’s EDID:
00 FF FF FF FF FF FF 00 30 E4 B1 06 A1 27 21 00
00 1F 01 04 A5 1B 12 78 03 EF 70 A7 51 4C A8 26
0E 4F 53 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 DE 8A 40 78 B0 80 37 70 30 20
55 00 12 B7 10 00 00 1A 00 00 00 FD 00 1E 78 F0
F0 48 01 0A 20 20 20 20 20 20 00 00 00 FE 00 4C
47 44 5F 4D 50 31 2E 31 5F 0A 20 20 00 00 00 FE
00 4C 50 31 32 39 57 54 32 31 32 31 36 36 01 7D
70 13 2E 00 00 03 01 14 7F 15 01 88 3F 0B 4F 00
07 80 1F 00 7F 07 1F 08 41 00 07 00 03 01 14 7F
15 01 08 3F 0B 4F 00 07 80 1F 00 7F 07 4F 00 41
00 07 00 45 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90
I checked the native resolution of the Surface Pro 8 — it's 2880×1920. However, the KVM does not support resolutions higher than 2560×1440@60Hz. So I provided a custom 2880×1920@30Hz resolution as a workaround.
00 ff ff ff ff ff ff 00 05 e3 77 25 24 00 00 00
01 1e 01 04 a5 37 1f 78 3a 44 55 a9 55 4d 9d 26
0f 50 54 21 08 00 d1 c0 b3 00 95 00 81 80 81 40
81 c0 01 01 01 01 56 45 40 a0 b0 80 1b 70 30 20
35 00 29 37 21 00 00 1e 00 00 00 fd 00 32 4c 1e
63 1e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 47
4c 4b 56 4d 0a 20 20 20 20 20 20 20 00 00 00 ff
00 41 48 4c 4c 31 39 41 30 30 30 30 33 36 01 90
02 03 1e f1 4b 01 03 05 14 04 13 1f 12 02 11 90
23 09 07 07 83 01 00 00 65 03 0c 00 10 00 02 3a
80 18 71 38 2d 40 58 2c 45 00 29 37 21 00 00 1e
01 1d 00 72 51 d0 1e 20 6e 28 55 00 29 37 21 00
00 1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 29 37
21 00 00 18 8c 0a d0 90 20 40 31 20 0c 40 55 00
29 37 21 00 00 18 f0 3c 00 d0 51 a0 35 50 60 88
3a 00 29 37 21 00 00 1c 00 00 00 00 00 00 00 d0
system
Closed
July 12, 2026, 1:38am
4
