EM12-G issues with Brume 2
I’m having an issue with a Teradek Node 2 modem, which uses the Quectel EM12-G chip.
When plugged in to other GL.iNet products like the mini routers, i have no problem establishing an internet connection.
With the Brume 2, I get a message saying incompatible device.
I’m not techincally savvy enough to start digging through LuCI, but if anyone can advise or if GL.iNet can specify a way to make this modem work with Brume 2 it would be much appreciated.
Thank you
I’ve managed to get it to connect by doing manual setup and using ttyUSB2, with or without an APN.
however, it doesn’t consistently survive power cycles
Can you use usb external power supply?
