ifconfig wlan0 up –> no message (prompt is just back, no error message either)
I made a test with a cronjob: wifi down, five minutes later: wifi up.
Result: wifi did disappear at the given time and was visible even within the five minutes it was supposed to be off. And it did not propperly come up again after five minutes when “wifi up” was executed. I had to reset the router
Additional problem: how can I access the router when wifi is not working? Port 83 on wan side is for html only, right? Who can I enable/allow ssh on wan?
I had to reset the router using the button.
what do you mean by uci? I just know the linux interface you can reach by ssh. (By the way: how can I get help for commands? There are no man pages. What dialect of linux is it running?)
In oder to learn more about uci I shuld use your commands for disabling / enabling in the script… but as it works now… I 'll let you know when I have more results.
