Enable Shell History?
Is there a command that I can type into my SSH session that will enable the shell history? One that survives a reboot?
If not does anyone have a shell script that would start it, so I can use arrow keys to scroll through the command history?
I searched the forum but nothing obvious came up.
Thanks :pray:
Can you try to install bash as per:
Then update your shell for root in /etc/passwd by replacing ash with bash:
root:x:0:0:root:/root:/bin/bash
Thanks for that, I had a wee look at it, but it’s quite a bit more complicated and daunting than I thought, I was hoping you could just type a command or pop a script into a dir that ran at boot.
I use Merlin on my Asus Router and there’s an amtm option for shell history, I was hoping for a similar option. No biggie, I can retype or copy paste commands.
