How do I enable upnp on my mt 1300?
I installed luci and a plugin I thought, but I don’t see it anywhere
Do you have installed luci-app-upnp also?
After installed you have to logout from luci and login again and it must appear under Services tab as Upnp.
It’s kind of dangerous to allow automatized ports to be opened remotelly. I advice you at least to disable “Enable NAT-PMP functionality” . Ports will be opened by applications as well.
