Hi, everyone,
My question is simple and probably easy. I have my GL-inet AR300M16-ext set up behind my main router for my home network. I want to be able to access the configuration using it’s IP Address that my main router assigns. On most routers, they have a section where you can enable this via HTTP or HTTPS, but I don’t see it on the GL-inet. *I DO NOT WANT TO ACCESS IT FROM THE INTERNET
Is this just a case of implementing the WireGuard server like Remote Access Web Admin Panel - GL.iNet Docs 4 and pointing it to the 192.168.2.2 IP that my main router gives it? Or do I have to do something more? (to be clear, I want to be able to access the configuration by going to 192.168.2.2 on my main network)
Have a great evening.
Patrick.
