Just installed 4.0 beta 8 for couple hours, I found some DNS related issues:
- DNSCrypt servers can’t be remembered ? (once you select couple servers, then you choose other type of encrypted DNS type, then switch back, you have to select the servers again)
- DoT is not working for me: (I select DoT+NextDNS combination, then enter my NextDNS ID, click apply then the DNS is not working, I can’t resolve any hostname and the system log has some Stubby repeatedly crash records )
It reads that Stubby can’t parse the auto-generated configure file to cause the crash. (the configuration file it stated seems look normally)
