We’ve recently released new firmware versions for specific GL.iNet routers to address some critical security vulnerabilities we’ve found in them. This update includes fixes for CVE-2023-46454, CVE-2023-46455, CVE-2023-46456, CVE-2023-47463, CVE-2023-47464, CVE-2023-50919, CVE-2023-50920, CVE-2023-50921, CVE-2023-50922, CVE-2023-50445, and CVE-2024-27356.
To ensure the optimal security for your router, you are advised to upgrade your router to the latest firmware if you’re affected. If you want to learn more about the latest firmware version (including the OpenWrt version) available for your router and your router’s support status, visit the Firmware Status Update page.
For any questions, please send us an email at [email protected] at any time.
Hi eric, thank you for your question! These security vulnerabilities affected particular router models running firmware v4.x. microuter-N300 runs on firmware v3.x, which was not affected.
GL-XE300 Puli V3.217 and earlier Needs upgraded to: V4.3.16
GL-X750 Spitz V3.217 and earlier Needs upgraded to: V4.3.11
GL-SFT1200 Opal V3.217 and earlier Needs upgraded to: V4.3.11
So why do these 3 routers running V3.x code need upgraded to 4.x to fix security issues and the microuter-N300 does not need a 4.x upgrade for SECURITY ISSUES. Are there no open CVEs in the currently available firmware for the microuter-N300
I think this might have erased all my static IP assignments. And now my Echo cant control or rediscover my wifi switches. Not to sound accusatory, the updates are necessary for sure, and I can deal with redoing the static IPs no big deal but I’m trying to figure out why the Echo can’t find my switches. One theory I have might be Upnp related according to this article
Any help would be appreciated
So after logging in to my Puli router today, I got notified about an update (claiming security updates and fixes).
After doing the update I've lost a feature I used and preferred (Quad9 Encrypted DNSCrypt-proxy),
The only options for encrypted-DNS are DNSCrypt-proxy and DNS-over-TLS neither of those have quad9 as an option. (Side note: I would be Very happy if I could use DNS-via-HTTPS)
Please Re-add the ability to use DNSCrypt-proxy via Quad9, I have used them for years with great satisfaction, It used to be there in the drop-down list, is there a reason for its removal?
For convenience here is a link where the configs/.TOML can be found.(feel free to remove if unnecessary)
