Enhanced tailscale plugin broken on brume3
until last version it was possible to update the plugin from the tailscale gui just pushing on the update symbol.
i tried today to update it from the gui but notjing happens.
should i reinstall it or there is another solution?
Since this plugin is a 3rd-party-one, you should inform @rthco about it.
But I would recommend to update the plugin manually and test if it works again.
i updated it with Luci, and it works for everyhing except tailscale ssh button
