Enhancements: GLKVM app
For the GLKVM app on MacOS it would be helpful:
  1. When the GLKVM window can be closed or adjusted in such way that it does not get in the way of the Session Control window.
    When switching between other apps and the GLKVM app, the GLKVM window opens on top of the Session Control window, even when I minimized GLKVM window.
  2. When in full screen mode, the copy/paste field can be made visible/invisible with a keyboard shortcut.
  3. If an option can be implemented to hide the text which is copied in the copy/paste field in order to prevent shoulder surfing.
Keep up the good work! Thanks, Jony
1.We will improve the Windows interaction in the next app upgrade
2.We added a hotkey for the paste feature in firmware 1.11(Maybe release next month)
3.Yes,we implement this too,also in firmware 1.11
That’s very good to hear, thanks!
