What is AT command on EP-06 modem to see if it obtained GPS fix and what are coordinates?
Thanks
The EP06 module does have a GPS receiver inside, but it does not have an antenna, nor does any of the GL products include a GPS antenna (2019).
I would also not recommend using any of the build in GPS on the Quectel modules as it is very weak. You won’t get a signal indoors or even near a window and slow updates outdoors.
You are better using a dedicated GPS module such as the uBlox M8N. They are cheap and you can get commands over USB.
Quectel EP-06 does support GNSS, but you’ll have to use a passive antenna, which hurts performance indoors - active antenna can provide up to around 17 dB of gain, which is fairly significant considering the signal levels of GNSS…
See section 3.9.4 of the document below
https://www.quectel.com/UploadImage/Downlad/Quectel_EP06_Hardware_Design_V1.0.pdf
to enable GPS - this isn’t in their AT commands doc
AT+QGPS=1 on /dev/ttyUSB2 and you’ll see the NMEA sentences on /dev/ttyUSB1
enjoy
