PROBLEM SOLVED: JUST ENTER THE MULLVAD-ACCOUNTNUMBER MANUALLY
What happened before: …
Trying to add Mullvad as Profile in Wireguard Client … but it does not work …
Here’s what I do:
Go to VPN -Settings, Wireguard Client
Add New Profiles
Go to other, choose Mullvad, enter Accountnumber
ar750 throws error “add failed”
I tried with Firmware versions stable and testing (disabled “keep settings”):
gl-ar750-3.010
gl-ar750-3.013-0129
… same error each time
I bricked my ar750 and had to use uboot to get it going again, tried again with both firmwares, no change, still error on adding mullvad.
please help
PS: the same happens, when I try to add mullvad profile for wireguard client on router model AR300M-ext, with both standard and testing firmware … same errors
… nope, thanks … i bricked my routers often enough & rather wait till the pretty idea gl.inet already shows off really works … after all there already is a button to easily add new wireguard profiles … it’s just not working … like an escalator that turns out to be just stairs …
Please bear with me, not trying to sound like a douche. Just trying to help.
We have 50 private WG servers worldwide using KVM VPS servers. (FYI Mullvad keeps logs, not good.)
We also have many AR3300m and a few AR750s for work/travel. It’s too hard to continually re-add the WG servers into each version’s update, so we make backup copies of the ‘wireguard’ and ‘shadowsocks’ files before updating to the next version
For us, SFTP is the easiest way., it’s super fast and you can just overwrite the default files in seconds. If you don’t have the saved files, you can also just add your keys and info manually there. Did I say fast?
Just for drill if you don’t have this.
-Create an SFTP server:
SSH into the router, then
opkg update
opkg install openssh-sftp-server
Then, SFTP into the router. Go to /etc/config/.wireguard. Simply overwrite wireguard with your saved wireguard file, or you can manually add each entry into it like this:
It works for me. Not sure why you can’t add it. Could you please PM me your account number? So that we can debug this issue. If it is possible, you can send it to [email protected]
I just had my “d’oh” moment & feel like Homer Simpson … I really should have thought of that.
Entering the account-number manually solves all problems
God, Mulvad is fast compared to OpenVPN … BUT:
Mullvad does not let me stream TV-Content from country A, when travelling in country B … same as Netflix: just doesn’t work through Mullvad/Wireguard…
but this is a Mullvad issue, no gl.Inet one. Those routers just rock.
Good to hear such a simple solution fixed it, DOH!
The error normally occurs because when you cut and paste the password, sometimes you get a trailing space.
