Error listing directory '/etc/config'
My GL-AXT1800 has lost connection to VPN and rebooted itself today after more than 3 days of some initial promising consistency using the latest stable 4.4.6. This was disappointing and I decided to access router via WinSCP to backup my DHCP reservation prior to trying a different firmware but I ended up getting this error on WinSCP:
2023-10-05_232203
Any ideas what this signifies?
Are you able to log in via SSH and run:
ls -l /etc/config
I should have thought about trying that at the time, shouldn’t I? Unfortunately, I reset and reflashed with the snapshot version but will definitely try SSH if I come across this again. Just thought someone might know the reason for this error and why it has occurred after router’s spontaneous disconnection and reboot.
I think the router went into ā€˜failsafe mode’ mode during startup.
If you encounter a problem again, you can save the complete log information.
Thanks. Will there be a way to get out of that ā€˜fail safe’ mode if it happens again?
Maybe this:
