I prepared the first one for my brother to use IPVanish, uploaded the config.zip file from IPVanish, entered my email and password, and it works just fine.
When I started doing my own, I keep on getting an error “error no parameter found”.
I am able to upload the config.zip file, no problem, but when I enter my email and password, as soon as I click on “Submit” I get the error again.
Both routers are updated to firmware version 3.105
Was yours set to factory reset before you tried on 3.105?
The reason I ask is because that was the case with both our routers.
In any case, I have mine in 3.104 for now since I know it works for me.
I’ll upgrade when the next version is out and see if I can replicate the issue then (hopefully not).
Thank you very much for trying on your end, I really appreciate it.
I’m replying to my own message in case someone stumbles across it. I contacted gl.inet tech support who sent me a beta 3.21 version of the firmware and that fixed the problem for me. You should find it in the ‘testing’ folder on the firmware download site. If not then write to tech support. They do have a firmware version that works with IPVanish. I’m happy about this because so far, I’m liking both IPVanish and my new router. I’d hate to have to replace either one.
