“java.net.SocketTimeoutException: connect timed out”
I can’t connect to two routers.
We have now fixed this problem.
I just started experiencing this problem today, so I do not think is is fixed as you have stated.
I keep having problems.
SORRY, I was referring to fixing the login error.
I missed that there was a timeout issue up there.
Under what operation did you get the timeout prompt?
