ESC key does not pass through from macOS to Windows PC
I am connecting to a Windows laptop from macOS using GLKVM app and ESC keypress does not pass through.
I confirm this by running this keyboard tester in a browser in the remote machine :
What makes it worse is that the Esc key exits full-screen mode. This is very annoying !!!
I do NOT want to have to use a soft-key option like the virtual keyboard.
What i want is the ability to simply pass the Esc key through to the device. I actually think this should be the default behaviour. Please implement this.
By the way, there should be other options to exit full-screen mode. Parallels for example uses long-press of Ctrl and Alt keys. Or on macOS you could use the fn+f combo or similar. Whatever it is please make it configurable.
I just tried connecting directly to the KVM from a browser on my macOS host and the experience is better :
  • ESC key DOES pass through
  • ESC key does NOT exit full screen (unless i hold it down as the browser instructs)
There is still no key mapping though.
This is a workaround that is satisfactory but i would like to see better support for ESC pass-through in the GLNet app
Sorry for the inconvenience caused.
We have tested that this bug do exist when a MacOS run GLKVM APP in 1.2 version.
This will be fixed in future version ASAP, you can please use glkvm.com temperarily.
Sincerely appreciate your feedback, we will try our best to avoid this kind of issue happen again.
use chrome in any OS, you will get a better experience
